Have a nice day, I just switched from classic Fiber broadband to ultra fast 500Mbps, but I can't connect at all using my asus DSL-ac88u router. On the classic fiber, I just wrote the name btinternet@btbroadband.com and the password bt and everything went fine, but it don't want to connect it here and it just gets stuck here. It write me Your credentials are currently chcked. And nothing more. Can you please advise me?used vlan ID 101.thank you
Solved! Go to Solution.
FTTP doesn't use VLAN ID so clear that field on the router.
Ou, thats easy. Work. Thank you
