Message 1 of 10
Ultrafast broadband
We are thinking of moving house and the property currently has standard broadband. I believe Ultrafast Openreach is available and would like to know what is involved in making that happen, plus any cost implications moving forward.
Many thanks
9 REPLIES 9
Message 2 of 10
Re: Ultrafast broadband
If you visit BT.com you will be able to see what's available to you at what price and any set-up costs
Message 3 of 10
Thank you. However we haven’t bought the property yet so I’m trying to check things remotely (so it’s not like checking what’s available to me where I currently live). I don’t know how to do that. As I work from home this is a crucial part of our decision about whether to buy the house.
 Thank you again
Message 4 of 10
If you put the full address (not just postcode) in the checker you will see what is available. Post a screenshot of the results if you are not sure. https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 5 of 10
@licquorice  I was just about to post the same link 👍
Message 6 of 10
Thank you both - I’ll give that a try
Message 7 of 10
Hi
So I've managed to get the results which is great but I'm not sure I understand what they mean. As suggested here's a screenshot:
I really appreciate your help. Thank you
Message 8 of 10
Its your lucky day, fibre to the house (FTTP) is available with 1Gbs speed. Should be plenty fast enough!!
Message 9 of 10
My lucky day indeed!! Thank you so much for your help - it's been invaluable (and so speedy).
All the best 😀😀
Message 10 of 10
Give the FTTP team a call when you are ready to order. 0800 587 4787
