James-M-Johnson
Message 21 of 25
Re: Unable to Order FoD ?
So.. progress... kind of
I've had a response from BT Openreaches Network Relocation Team stating that I need to get a provider to manually raise a request for a new line requesting for it to be routed to the aggregation node.
However BT have said they have no way of specifying or adding notes when they raise an order.
I presume this is why it has to be manually raised ?
(Note - I'm still awaiting a response from my sites developer)
Webby
Message 22 of 25
Unless it's already available, BT retail, won't be able to place an order.
It would likely have to be Openreach systems updated first to show you can be served from the node, before that would filter down and allow an order to be placed.
pippincp
Sage
Message 23 of 25
The fault here lies with the developer. Had they worked with Openreach from the outset then every house on the development would have ducting in place and the ONT installed ready for the fibre to be installed.
Once develpers realise the pure fibre is a selling point they may then do it.
Webby
Message 24 of 25
The issue is that the developer HAS now asked for native FTTP but the OP's property was the last to be served by copper. Their next door neighbour has native FTTP.
pippincp
Sage
Message 25 of 25
The issue is that the developer should've worked with Openreach from the outset for FTTP to be supplied to all properties in the development.
Obviously they didn't.
