abathingape
Message 1 of 10
Unable to Perform BT Speedtest
I'm not sure if this is a wider problem but for a while now I've not been able to perform the speedtest from http://speedtest.btwholesale.com/.
The initial speed test is ok but when trying to progress to "furhter diagnostics" I receive the following:
Test Error:
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Any ideas?
9 REPLIES 9
imjolly
Message 2 of 10
Re: Unable to Perform BT Speedtest
this is a current problem and there other posts on the forum just like yours  it is not your conenction that is a problem  often if you persevere then it works  you can also try a different browser which sometimes helps
Liam_
Recognised Expert
Message 3 of 10
The wholesale speed tester has been having some issues recently.  Only thing you can do is persevere it should eventually run the test with out errors.
abathingape
Message 4 of 10
thanks guys.  Also I have just recently switched to Sky, and as helpful as you guys have been in the past, I'm guessing I'll have to raise any issues on their forum instead of here?
Liam_
Recognised Expert
Message 5 of 10
That's correct.  Sky's system is their own and none of the BT staff would be able to help.
abathingape
Message 6 of 10
no probs fella. thank you
Keith_Beddoe
Message 7 of 10
I an not sure it works on other ISPs, so you would be better asking on the Sky forum.
Park_Ranger
Message 8 of 10
The BT Wholesale speedtest works with other ISP's.
The Further Diagnostics doesn't.
abathingape
Message 9 of 10
Ah that explains why! So how would one determine what the 'profile' of their line is?  Would that have to go through the necessary chain on their respective ISP too I guess?
imjolly
Message 10 of 10
as you are now a sky user then try sky forum as you will probably find the answer to your question has been raised and answered there
