MurleyCat
Message 1 of 9
Unable to access certain sites (National Lottery, Majestic etc) with new BT Smart Hub
Happens across all products, Apple and Windows and all browsers
Seems to effect sites which are age restricted, i.e. lottery you have to be 18 and majestic you also have to be 18 to purchase the wine, Apollo e-cigs
Example of error message on safari it states it cannot connect due to a lack of secure connection
Can access sites using my phone off wifi
Parental controls off
tried DNS 8.8.8.8
turn hub off
factory reset of hub
turning off firewall
nothing works and BT call centre have no clues either, very frustrating.
any ideas?
8 REPLIES 8
Keith_Beddoe
Message 2 of 9
Re: Unable to access certain sites (National Lottery, Majestic etc) with new BT Smart Hub
If it affects all devices, first make sure that smart setup is turned off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Then login to MyBT and make sure that BT Parental controls are not set to restict content to over 18s.
You cannot use other DNS servers without totally uninstalling BT Parental controls, and making sure BT Protect is turned off.
MurleyCat
Message 3 of 9
Hey thanks, Smart Set Up off, Checked BT account and made sure parental controls are off, and BT protect is off.
still no joy, just restarting the router.
Have you any other advice?
Thanks again
graystreet
Message 4 of 9
Haved you tried turning off your AV software, obviously just for a shoirt time, and accessing one of the sites then?
MurleyCat
Message 5 of 9
Issue still ongoing after nearly a month. BT call me nearly every day (level 1 support) but they don't have a clue. Basically they ask me to the same thing every day, try a different browser, different device, etc. Factory reset, turn it off. Then they say level 2 support will call you. Level 2 support have never called back. It's pretty awful service.
As far as I can tell it's either the BT SmartHub 6 doing this or parental controls has a bug and is over riding the off setting.
Anyone got got any ideas, I feel like we are being left to try fix this by ourselves as BT are not going to.
:o(
Liam_
Recognised Expert
Message 6 of 9
Hi,
Try Tor Browser. It will bypass any ISP filters and also bypass filters set in your router. If you can access the problem pages using Tor then something that says it's off is still on.
MurleyCat
Message 7 of 9
Yes we could access with Tor. So that proves its the router or BT.....
Liam_
Recognised Expert
Message 8 of 9
Well it certainly points to an external fault, so not any of your personal equipment.
I suspect it's either a glitch with turning off the "Protection" software, namely:-
BT Parental Controls
BT Protect
or BT NetProtect Plus
They really are a waste of time and of very limited utility as demonstrated by using the Tor Browser.
The alternative is the hub itself, which is a possibility seeing all the reports of problems with the new "Smart" Hub. Quote from the BT sales pitch, "Get a hub that helps you out. This is clever. The BT Smart Hub constantly monitors your internet connection. If it spots a problem, it will quietly reboot and make a fresh connection."
So, if the thing itself is a bit iffy the above could explain the connection drops people report.
I never use hubs, got 3 of them in their boxes. Best bet is to buy your own quality third party modem/router. The hub apparently retails at £130 + P&P. For that amount you can get a really good one.
MurleyCat
Message 9 of 9
Thanks, We have gone out and purchased a new router will trial it this weekend.
