Solved! Go to Solution.
You should not need to do all that. If you go to where the wireless connection is showing at the bottom right of your task bar. Click on it. It wil bring up all the wireless networks that your laptop can see.
Find the one that has your Homehub name. Click on it and enter the wireless passkey that is on the Homehub label and tick the box "connect automatically". You laptop should then connect.
This is the problem. It's not bringing up my wireless network. It sometimes brings up another wireless network but not mine. It's also brought up Sky and BT Fon but not my hub. It should be simple.
Try ONE factory reset of the Homehub by pressing a pin into the recess button on the rear for about 20 seconds. Then go through the set up process again.
Thank you. The factory reset seems to have worked.
