Milog
Message 1 of 4
Unable to connect network / WiFi printer to Home Hub 4
I have just had Infinity and Home Hub 4 installed. My Samsung ML-2525W printer was working fine via my previous Netgear DG834. Now it won't connect by ethernet or Wi-Fi.
If I reconnect my PC and printer to the Netgear router it prints; if I change the connections back to the Home Hub it won't.
I've tried reinstalling the Samsung software, but it fails to detect any printers when connected to the Home Hub. I've tried setting up a static IP address using the Samsung SetIP utility, but even if I enter the details manually SetIP can't locate the printer either.
So, either the Home Hub is blocking the connection, or something else in my setup is. I've tried turning off the firewall, but it's still blocked.
The printer is reporting an IP address of 192.168.0.4; subnet mask 255.255.255.0; default gateway 192.168.0.1. The Home Hub itself is at IP address 192.168.0.1 (exactly the same as the Netgear router)
Any ideas welcome...
[should add that I'm on Windows 7]
3 REPLIES 3
john46
Message 2 of 4
Re: Unable to connect network / WiFi printer to Home Hub 4
abbottmj
Message 3 of 4
I have exactly the same problem with a Samsung ML-1630W printer.
Did you find a solution?
I was going to try the SetIP but it seems that didn't work for you.
Tags (1)
john46
Message 4 of 4
I suggest you also try the link i posted
