Message 1 of 2
Unable to login to My BT
I try to logon to the My BT site but the following message is displayed:
"Please check you entered your username and password correctly and try again. If you need help remembering your username or password you can use the links below."
I have reset my password but the result is the same. I know my details are correct because I have used them to sign in to the My BT app with success. Any help would be appreciated, thanks.
1 REPLY 1
Message 2 of 2
Re: Unable to login to My BT
Have you tried a different browser and or clearing the history and cookies from your browser?
