Message 21 of 24
Re: Unable to order FTTP but other houses can
I believe the DSL checker and Royal Mail address database are publicly available information...
Message 22 of 24
Hi, I was having exactly the same issue until yesterday. I used the online form and raised the issue and within 2 week I have now order fibre which should go live on the 9th March!
I used the form https://www.formwize.com/run/survey3.cfm?id=7214&embed
Good luck
Message 23 of 24
Your issue was regarding an FTTC cabinet that was full. This is provision of FTTP. Totally different I'm afraid.
Message 24 of 24
Thanks for the Formwize link.... Unfortunately I've filled that thing out 5 times in the last six weeks and all I ever get is a response saying they will look into it, then nothing happens. Glad to hear they did something in your case though and that someone does read the forms!
