Message 1 of 6
Unable to order Fibre 900
Any reason why I cannot order Full Fibre 900?
All I can order online as an existing customer if Fibre 250 at a higher price, so should I just bin BT and move to another provider who can supply that speed at a lower price?
5 REPLIES 5
Message 2 of 6
Re: Unable to order Fibre 900
Do you have FTTP? Is your area FTTPenabled? Enter your phone number HERE and post the result. Remove number before posting.
Message 3 of 6
Yes it is, otherwise I would not have opened a post.
WBC FTTP Upto 1000 Upto 220 -- Available 1 Stage
Message 4 of 6
Then ring the FTTP team. 0800 587 4787
Message 5 of 6
That was rather quick and painless, all sorted for me.
Thanks the assistance.
Message 6 of 6
You're welcome.
