TimCurtis
Recognised Expert
Message 21 of 45
Re: Unable to record Bt sport on Youview
@russianmonkey wrote:
I'm currently on a trial with a youview box using updated software that allows the recording so it should be out by the end of the year assuming there are no bugs!
At last something a little more promising, hopefully that all goes well.
Leebool
Message 22 of 45
Don't hold your breath. 🕛🕧🕐🕜
russianmonkey
Message 23 of 45
Well recorded Family Guy on Fox SD last night and quality looked alright.
Plus it was over powerline adapters!
Leebool
Message 24 of 45
Surprised they are allowing the trial recording of internet channels using power adapters.
russianmonkey
Message 25 of 45
That's part of the trial too.
If they can use powerline adapters for internet channels (HD ones too), then it means no engineer installs for extra channels.
It also means Multiroom becomes a more realistic possibility.
Leebool
Message 26 of 45
How does one get onto these trials?
russianmonkey
Message 27 of 45
This particular one is full but for future trials:
http://bt.centercode.com/
Leebool
Message 28 of 45
Thanks for the link.
walkerx
Recognised Expert
Message 29 of 45
If you are on a trial you abide by the T&C's when you sign up. Discussing any part of a trial you are on (or have been on) is in breach of these T&C's.
Colin_London
Recognised Expert
Message 30 of 45
Oh come on - this trial of internet recording is hardly a secret. The feature has been promised for Youview for the best part of a year and was bound to be being trialled around now (seeing the original target for release was October).
Plus there is nothing here that consititutes a commercial secret that would be of value to a competitor - it only helps assure customers that an update is near which is a good thing to reduce complaints.
