Colin_London
Recognised Expert
Message 31 of 45
Re: Unable to record Bt sport on Youview
Have to say that my 500Mbps Powerline adapters have streamed HD multicast perfectly since I got BT Sport. Powerline AV of 200Mbps or better should work fine for the majority of people - it's just the old 85Mbps ones that BT still provide that won't cope.
Distinguished Guru
Distinguished Guru
Message 32 of 45
So does anyone know why its has been delayed ?
Given that BT Vision have been successfully recording internet channels on what is generally accepted to be an inferior box for ages and Youview box has had  the capability to handle recording of two (linear) channels since the beginning and has had the capability to receive an internet channel stream since beginning of August it is scarcely credible that recording & playback of internet channels has taken so long to be provided.
Leebool
Message 33 of 45
Well said. 😋
russianmonkey
Message 34 of 45
Zulu, I'll be careful with what I say now.
At the moment, if you wish to use Extra Channels, you need to have your YouView or Vision+ box plugged directly into your hub using an Ethernet cable.
I'm guessing once that restriction is removed, then that could pave the way.
Icaras
Message 35 of 45
It's not a restriction. BT just won't support it as speeds over power line adapters vary wildly. I'm using powerline adapters and can play HD Internet channels fine.
sirjamesp
Message 36 of 45
"...original target for release was October."
The original promise was August, not October!
Leebool
Message 37 of 45
And another week ticks by without any word on the recording software update..
H12-FJK
Message 38 of 45
Merry Christmas
Stephen4232
Message 39 of 45
As far as I am aware I haven't signed up to any trial but I have been recording BT Sport in HD for 2 months now. I recorded both Boxing Day games in HD and they played perfectly!
TimCurtis
Recognised Expert
Message 40 of 45
The software to record BT Sport etc was formally released to all about 21/11/2013.Smiley Happy
