Solved! Go to Solution.
Because you are on Infinity 1, your connection speed is being restricted to about 55Mbs. The maximum possible rate is showing as about 124Mbs, so there is a large margin of unused bandwidth, hence the large noise margin.
If you upgraded to Infinity 2, your connection speed would be 80Mbs, but there would still be plenty of margin.
