Message 1 of 3
Unknown cordless phone.
Hi everyone.
Hopefully someone can identify this cordless phone?
I was part of the trial however at the time it was never given a model number.
I want to use the additional handset it came with for my father in law who has a 4600.
Thsnks
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
2 REPLIES 2
Message 2 of 3
Re: Unknown cordless phone.
Looks like the original BT4000 , ( Non TAM) Question What is on the bottom of the base or under the battery in the handset , any numbers?
Message 3 of 3
Thanks for the reply. I actually did a search on the picture after I posted the message and also reckoned it was the 4000.
There are no stickers on the base station or charger.
