Message 1 of 5
Unknown device on new wifi
Heoolo, I have just had new fibre installed. I have only aged a few things to the network and have two unknown devices attached to it. I have tried pausing them to see what goes off but nothing does. There is no IP address and when I put the MAC address into Google I cant seem to find anything.
MAC B2:95:75:F5:B0:F9
MAC B2:95:74:F6:B0:FA
Any help would be appreciated
4 REPLIES 4
Message 2 of 5
Re: Unknown device on new wifi
Do you have any powerline adaptors?
Message 3 of 5
Hi, thanks for the reply, I do have a powerline adapter too, how do I check if its them?
Message 4 of 5
It will be them but to check you would need to unplug them or the MAC may be shown on a label on the device.
Message 5 of 5
Brilliant
Thank you very much
