Message 1 of 5
Unknown device with Null IP Address
IMG_0384.PNGIMG_0384.PNGI've just installed my BT Smart Hub 2 and have one device listed as unknown and with a Null IP address.  The attached photo shows the details.  Anyone know what it might be?
4 REPLIES 4
Message 2 of 5
Re: Unknown device with Null IP Address
Switch off (or put into aeroplane mode) any iOS14 devices you may have then enter http://192.168.1.254/my_network.htm into a browser and click on the Remove button alongside the device, does it come straight back up when you reconnect the iOS device?
Message 3 of 5
Thanks for that Les.  I did what you suggested and both my iPad and iPhone were both added to list when I restarted them.
Message 4 of 5
As I thought, it's nothing to be concerned about.
See this link for more detail: https://support.apple.com/en-gb/HT211227
Message 5 of 5
Thanks very much for your help. That’s reassuring!
