Message 1 of 15
Unknown line fault
Hi
I been waiting for my broadband to be fixed for 2 days had a bloke out he checked all line etc his machine see exchange and talk to it.
He was on phone for a hour and half with ppl doing line tests all come back with no faults but the hh3 stays on soild orange bloke tryed 3 routers . After 2 hours he left saying he not see this before and bt wholesale told him a "hook and lift" won't work as all is fine.
So he packed up said they passed it on to 2nd line investcation and no other info .
So anyone had this ?
I'm on bt infinity 75meg with hh3
Gavin
14 REPLIES 14
Distinguished Expert
Message 2 of 15
Re: Unknown line fault
is it a line fault?
does the modem work ok? try it with another router
Message 3 of 15
Hi as I posted engineer try 3 HH's and modem they said working fine as right lights was on
Message 4 of 15
did he try a different modem?
Message 5 of 15
No trying diffent modem wouldn't make a diffent they said as they could "see it"
I asked about trying new one with same reply
Message 6 of 15
to me he should of tried a different router and then if that didnt work try a different modem and then progress to trying different cables not just try 3 routers
Message 7 of 15
does the phone work ok with no noise?
Message 8 of 15
Common sense that would be right corse .
I myself swapped out cables just both dsl and eithernet.
Same results. I would of liked try new modem but wasn't about argue with him over it.
Message 9 of 15
Hi phone works fine
Message 10 of 15
do you have another router to try?
you could set up a pc to use the modem directly as windows supports pppoe but this will put your pc on the net without a nat firewall
