lucymay
Newbie
Message 1 of 3
Unlimited Broadband downgrade?..
Hi all,
I was just wondering if any one knows if you can downgrade your BT broadband package online ?
I am currently paying for unlimited broadband & I don't use the internet much any more as I have a new baby. Its quite expensive & I can't really afford it at the moment 😞
I have been with BT for around 2 years now so hopefully I can change it
Lucy x
2 REPLIES 2
hamish72
Recognised Expert
Message 2 of 3
Re: Unlimited Broadband downgrade?..
Have you tried asking for a Migration code MAC as though you were going to change ISP if you do BT will give you your service at a much reduced rate to start a new contract
Don't worry about getting the MAC (if the do give it ) as it will expire in 30 days if not used with no effect on your service
I got a reduction of  £15 per month for option 3 and calls
Good luck wth it
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
wedd1ng528
Message 3 of 3
I suspect this will only happen if you're close to the end of your current contract Hamish.
wedding
Mistakes and embarrasing goofs in e-mails are only discovered when you've sent them!
