Message 11 of 22
Re: Unlimited Faster Broadband - is there a "hard" downstream speed limit?
You're absolutely correct that all of the improvements have been under my control, but there's generally been a lag between making the improvements and DLM acknowledging that things have improved and allowing me a higher sync speed.  If I was at 6(ish) dB SNRM I'd accept that my line was never going to support a higher sync speed...but as the SNRM is significantly above 6 dB, with very low ES and no retrains, logic suggests a higher sync speed should be possible.  I'm just trying to understand if I can get that higher sync speed by waiting for DLM to act (although it's been a month already since the last step up) or, if I've hit a hard-limit for my current service, by switching to Infinity 1 to remove the limit.  (And I recognise I'm in the realms of diminishing returns as I've never going to get more than a slight improvement until ADSL goes away and Openreach can crank up the power).
Message 12 of 22
can you post router stats
bt don't seel infinity 1 where speed is less than 15mb but they sell faster broadband  if you are lucky like some then you are able to get a speed faster than 15mb and spme even into the 20's
Message 13 of 22
Bt no longer make a distinction between Unlimited Faster Broadband and Infinity 1.
http://bt.custhelp.com/app/answers/detail/a_id/47740/~/what-is-unlimited-faster-broadband%3F
Message 14 of 22
Interesting that BT aren't offering the 18/2 profile.
Message 15 of 22
Here are the router stats taken a couple of mins ago - the SES and UAS are from when I manually restarted the router last Friday morning:
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason:    0
Last initialization procedure status:   0
Max:    Upstream rate = 529 Kbps, Downstream rate = 18196 Kbps
Bearer: 0, Upstream rate = 535 Kbps, Downstream rate = 13096 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        8.5             5.9
Attn(dB):        27.5            0.0
Pwr(dBm):        5.2             5.2
                        VDSL2 framing
                        Bearer 0
MSGc:           58              34
B:              31              16
M:              1               1
T:              49              17
R:              10              0
S:              0.0775          0.9784
L:              4336            139
😧              421             1
I:              42              17
N:              42              17
                        Counters
                        Bearer 0
OHF:            37180994                17044595
OHFErr:         347             14
RS:             1689996909              1158946229
RSCorr:         28668502                0
RSUnCorr:       41018           0
                        Bearer 0
HEC:            7198            0
OCD:            95              0
LCD:            95              0
Total Cells:    2843773666              0
Data Cells:     59511860                0
Drop Cells:     0
Bit Errors:     0               0
ES:             143             15
SES:            1               1
UAS:            23              23
AS:             283500
                        Bearer 0
INP:            3.50            0.00
INPRein:        0.00            0.00
delay:          8               0
PER:            7.62            16.69
OR:             67.15           19.16
AgR:            13163.05        553.83
Bitswap:        195543/195548           0/0
Message 16 of 22
so noise margin higher than normal 6db so if that reduced to nearer normal then that would give you a bit more speed nearer attainable  just need to maintain connection and wait for DLM reducing noise margin and hopefully raising speed
only way to get DLM reset is by engineer visit for a broadband fault and the fault being fixed then engineer can ask for DLM to be reset
Message 17 of 22
Interesting that DLM hasn't enabled G.Inp on your line, are you connected to an ECI cabinet?
Message 18 of 22
Yes, cab 4 is ECI
Message 19 of 22
Doh, forgot the OP had already posted cab info. Smiley Wink
Recognised Expert
Message 20 of 22
The 18/2 Package was trialled to try to persuade people on 21CN who lived within spitting distance from the Exchange to move over to VDSL.
Most said they wouldn't switch to VDSL as they were happy getting 16mbps and didn't want to, or couldn't justify paying extra for VDSL when they didn't need it because contrary to popular belief not everyone wants or needs Superfast Broadband.
BT/Openreach brought out the 18/2 in the hope they'd make the swap and it would look good on those Broadband Reports that shows X amount of people have swapped onto Fibre.
Also they wanted everyone on VDSL/G.Fast/FTTP soon because they want to scrap Exchanges and put people on Naked DSL. Although that might end up dead in the water because the LLU Providers are kicking off that it'll be unfair. 😒
