tally100
Message 1 of 4
Unreliable broadband
Hi Since we moved from solid 8mb ADsl to 17mb ADSL2 about 2 years ago i have been getting loss of internet and drops in connections and Vo4 errors on  BT Vision box every few months.Line tests ok and about 6 engineers ( Broadband Boost) have been out and never found a problem.They have done a lift and shift in the exchange,new underground cables changed out, new home hub 3, new nte 2000 linebox and cat 5 data cable direct to router and a RFI filter fitted. blue light does not go off when loss of internet or slow connections, but i can ping bbc.co.uk when it happens.The only thing not changed is supplier. stats from router below router swopped with my business broadband to see it it changes.
Home broadband with the problem
Line state: Connected Connection time: 0 days, 01:24:35
Downstream: 16.37 Mbps
 Upstream: 1.102 Mbps
  ADSL Settings VPI/VCI: 0/38 Type: PPPoA Modulation: G.992.5 Annex A Latency type: Fast Noise margin (Down/Up): 6.0 dB / 6.1 dB Line attenuation (Down/Up): 27.0 dB / 15.5 dB Output power (Down/Up): 20.4 dBm / 12.8 dBm FEC Events (Down/Up): 0 / 0 CRC Events (Down/Up): 30955 / 31385 Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 HEC Events (Down/Up): 8642 / 182261 Error Seconds (Local/Remote): 4097 / 1080
Business hub  3 stats Line state: Connected Connection time: 0 days, 01:28:20 Downstream: 17.07 Mbps Upstream: 1.025 Mbps     ADSL Settings VPI/VCI: 0/38 Type: PPPoA Modulation: G.992.5 Annex A Latency type: Interleaved Noise margin (Down/Up): 3.1 dB / 5.9 dB Line attenuation (Down/Up): 26.5 dB / 15.8 dB Output power (Down/Up): 20.2 dBm / 12.6 dBm FEC Events (Down/Up): 19535144 / 17855 CRC Events (Down/Up): 459 / 28296 Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 HEC Events (Down/Up): 827 / 219832 Error Seconds (Local/Remote): 370 / 7893
3 REPLIES 3
Message 2 of 4
Re: Unreliable broadband
Hi Welcome to the forums
Here are some help pages done by CL Keith http://www.btinternet.com/~cbeddoe/speed/Speed.html
Can you also post the full results fromBT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socketTest Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Then someone here may be able to help and offer more advice.
This is a customer to customer self help forum the only BT presence here are the forum moderators
tally100
Message 3 of 4
1. Best Effort Test: -provides background information.
 Download  Speed
 12.05 Mbps
0 Kbps21 Mbps Max Achievable Speed
Download speedachieved during the test was - 12.05 Mbps For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps. IP Profile for your line is - 12.1 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 928 Kbps
0 Kbps832 Kbps Max Achievable Speed
Upload speed achieved during the test was - 928Kbps Additional Information: Upstream Rate IP profile on your line is - 832 Kbps
We were unable to identify any performance problem with your service at this time. It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly. If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
broadband was reset yesterday by engineer it usually shows 17mb connection and 14mb ip profile but does show red download 1.6mbs yestreday
Yes no noise online and its been tested into test socket.
Message 4 of 4
your hub errors are very high for your connection time which is indicating some noise on the line which may cause disconnections and affect your throughput these need
to be reduced
I suggest you look at the interference pat of the link I posted for some possible ideas
