Message 1 of 1
Unstable FTTC speedtest results
I monitor my broadband speeds hourly from a machine connected by a Gigabit link to the router.
I had not checked it for a while but the results have progressively got worse recently.
Prior to the gap in the data (the testing device had a hiccup and I didn't notice), speeds were pretty reliable. About this time there was a local issue with Broadband and it was  - as it was a general issue, I don't have a date/fault report. My usage pattern has remained stable over this timeframe.
I do not use the BT Hub for anything other than as a modem - everything else is Ubiquiti gear.
Noise etc looks OK. I note the log entries/events keep occuring.
My suspicion is equipment fault at Openreach / BT end of things.
Thoughts?
DSL uptime: 3 Days, 4 Hours 2 Minutes 58 Seconds
Data rate: 15.81 Mbps / 71.92 Mbps
Maximum data rate: 15809 / 73161
Noise margin: 6.1 dB / 3.2 dB
Line attenuation: 33 dB
logs
18:22:55, 08 Mar. :WAN DHCPv6 Client Prefix : 2a00:23c8:7583:8600::/56 (valid time = 315360000 / preferred time = 315360000)
18:22:53, 08 Mar. ppp1:The WAN DHCPv6 Client Process has successfully been launched on Vlan 36
18:22:53, 08 Mar. ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
12:18:34, 08 Mar. ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
12:18:34, 08 Mar. ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
12:18:34, 08 Mar. ppp1:TR69 receiving InformResponse message
12:18:33, 08 Mar. ppp1:TR69 event found : 4 VALUE CHANGE
12:18:33, 08 Mar. ppp1:TR69 event found : 2 PERIODIC
12:18:32, 08 Mar. ppp1:TR69 sending Inform message
12:18:32, 08 Mar. ppp1:TR69 event found : 4 VALUE CHANGE
12:18:32, 08 Mar. ppp1:TR69 event found : 2 PERIODIC
12:18:31, 08 Mar. ppp1:TR69 sending Inform message
12:18:30, 08 Mar. ppp1:TR69 creating new session with ACS
09:45:06, 08 Mar. ppp1:Request for a new authenticated connection
09:45:06, 08 Mar. ppp1:TR69 ConnectionRequest: processing request from ACS
06:19:18, 08 Mar. ppp1:Request for a new authenticated connection
06:19:18, 08 Mar. ppp1:TR69 ConnectionRequest: processing request from ACS
06:19:17, 08 Mar. ppp1:Request for a new authenticated connection
06:19:17, 08 Mar. ppp1:TR69 ConnectionRequest: processing request from ACS
20:01:07, 07 Mar. ppp1:Request for a new authenticated connection
20:01:07, 07 Mar. ppp1:TR69 ConnectionRequest: processing request from ACS
