Message 31 of 43
Re: Unstable connection / high ping spikes
I am also having this EXACT problem on my PS4 with high ping spikes, and have completed ping tests similar to the images in the original post. I have sent messages on social media to BT and got nothing back. Sign me up to the petition, its the only way.
Message 32 of 43
For anyone who hasn't seen it already,I'll link an article where it shows Bt have admitted there is a problem at last.
It might help to push this if you comment at the bottom.
https://www.ispreview.co.uk/index.php/2019/08/customers-of-uk-isp-bt-see-multiplayer-lag-spikes-duri...
Message 33 of 43
It's progress, but I'm not hopeful. PR probably whipped up that response five seconds before clocking off.
Message 34 of 43
Been having the same issue as you, to the same Path of Exile server as you! Obviously its not an issue on our side then.
Message 35 of 43
Hi,
Did you ever get this resolved?
Joined BT myself last week and I'm getting this after 2 days of good gameplay:
Pinging google.co.uk [2a00:1450:4009:81a::2003] with 32 bytes of data:
Reply from 2a00:1450:4009:81a::2003: time=12ms
Reply from 2a00:1450:4009:81a::2003: time=13ms
Reply from 2a00:1450:4009:81a::2003: time=1736ms
Reply from 2a00:1450:4009:81a::2003: time=11ms
Reply from 2a00:1450:4009:81a::2003: time=2143ms
Reply from 2a00:1450:4009:81a::2003: time=16ms
Reply from 2a00:1450:4009:81a::2003: time=2136ms
Reply from 2a00:1450:4009:81a::2003: time=15ms
Reply from 2a00:1450:4009:81a::2003: time=2153ms
Reply from 2a00:1450:4009:81a::2003: time=14ms
Message 36 of 43
Get out while you can! I'm locked in, wish I had noticed it during the 2 week period.....
Message 37 of 43
I’ve also got this same issue and waiting for a solution as my internet was fine about a year ago and now I can’t play online games on my pc I also got the netgear xr500 and made no difference
Message 38 of 43
Just an FYI on my previous post.
I actually found the root cause of my issue, it was my onboard wifi (ROG Maximus code X)- The antenna that plugged into the board and sat on top of my desk.
I didn't, however, try to connect to the WiFi via a different method.
I changed this to a wired connection and the issue stopped.
Thanks,
Lee.
Message 39 of 43
This still happens. Every 2-4 seconds I get a jump from <10ms latency to >500ms latency.
BT really needs to do something about this stuff because forcing streaming packets (which ill be honest do not care about latency) ahead of LATENCY-SENSITIVE packets is a stupid idea.
Message 40 of 43
Well supposed to have an engineer come today I took the day off work, he didn’t arrive and then when I rang them they told me he was booked but the engineer wasn’t told when to arrive. It’s now Wednesday till they can come out
