Deckysw
Message 1 of 37
Unstable high latency problems
Over this past few weeks I have been suffering high latency problems. My ping seems to vary anything from 43ms to 900ms.
Now during online gaming which is near impossible to get the connection sort of playable I have to keep doing speedtests on my phone which will leave the game playable for approx 45seconds.
The console is a xboxone i have tried it wired via homeplugs and wireless same result for both.
36 REPLIES 36
Deckysw
Message 2 of 37
Re: Unstable high latency problems
Now today I spoke to bt and they reset my broadband. Now i know this will take a while to stabilise but it was really bad this evening. Hub 3 results below. Are the noise margins for up too high?
Deckysw
Message 3 of 37
I should have also said my hub 3 router is conected to an openreach socket via a cat6 cable. I have also done a quiet line test and it seems fine.
any help on solving this matter will be appreciated.
john46
Message 4 of 37
please post a tracert to bbc.co.uk also I would suggest a wired connection as both home plugs an wireless can suffer from latency issues
Deckysw
Message 5 of 37
Thank you John46 for your reply. Unfortunately I can't run a direct wired connection from my router to the console due to were each is situated.
Now to do the tracert to bbc.co.uk am I correct in saying that I do that via the command prompt on my laptop/desktop?
As you can tell by that question that I have never done it before but I will do that tomorrow afternoon and post the results here.
I have been using the homeplug set up now for a few years and never had these lag issues as bad until this past few weeks. I have tried changing the hub and I have also tried a different xbox one as well to take them out of the equation.
john46
Message 6 of 37
yes that is correct you need to run it when your latency is bad home plugs are not home plugs and wireless are not really the most reliable as external interference can cause problems direct Ethernet is always the best
Deckysw
Message 7 of 37
John46 here are 3 different tracert results from bbc.co.uk all 3 tests were carried out today between 16:40 and 17:50 it hopefully should give you some idea to whats happening
Microsoft Windows [Version 10.0.10240]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\Users\lipsyboi>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.244.22]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms BThomehub.home [192.168.1.254]
2 37 ms 36 ms 36 ms 217.47.108.250
3 47 ms 36 ms 35 ms 217.47.109.193
4 35 ms 36 ms 36 ms 213.1.69.198
5 35 ms 36 ms 36 ms 31.55.165.251
6 35 ms 36 ms 36 ms 31.55.165.109
7 35 ms 36 ms 35 ms acc2-xe-4-2-2.mr.21cn-ipp.bt.net [109.159.250.244]
8 46 ms 46 ms 46 ms core2-te0-12-0-1.ealing.ukcore.bt.net [109.159.250.147]
9 45 ms 44 ms 59 ms peer2-xe3-2-1.telehouse.ukcore.bt.net [109.159.254.225]
10 119 ms 131 ms 118 ms 195.99.126.71
11 * * * Request timed out.
12 * * * Request timed out.
13 48 ms 47 ms 48 ms ae0.er02.telhc.bbc.co.uk [132.185.254.105]
14 45 ms 45 ms 46 ms 132.185.255.148
15 45 ms 44 ms 44 ms 212.58.244.22
Trace complete.
Tracing route to bbc.co.uk [212.58.246.78]
2 829 ms 780 ms 709 ms 217.47.108.250
3 957 ms 840 ms 927 ms 217.47.109.161
4 618 ms * 276 ms 213.1.69.198
5 681 ms 762 ms 816 ms 31.55.165.251
6 1403 ms 1073 ms 314 ms 31.55.165.109
7 1455 ms 1456 ms 1127 ms acc2-xe-4-2-2.mr.21cn-ipp.bt.net [109.159.250.244]
8 485 ms 1358 ms 1436 ms 109.159.252.225
9 1155 ms 953 ms 754 ms peer2-xe0-0-0.redbus.ukcore.bt.net [109.159.254.74]
10 897 ms 966 ms 889 ms 195.99.126.73
12 1079 ms 268 ms 145 ms ae0.er01.cwwtf.bbc.co.uk [132.185.254.93]
13 898 ms 334 ms 946 ms 132.185.255.165
14 1414 ms 1351 ms 1204 ms 212.58.246.78
Trace complete.
2 640 ms 692 ms 722 ms 217.47.108.250
3 623 ms 635 ms 647 ms 217.47.109.193
4 36 ms 37 ms 35 ms 213.1.69.198
5 124 ms 96 ms 95 ms 31.55.165.251
6 204 ms 215 ms 224 ms 31.55.165.109
7 35 ms 35 ms 35 ms acc2-xe-4-2-2.mr.21cn-ipp.bt.net [109.159.250.244]
8 47 ms 46 ms 46 ms core2-te0-12-0-1.ealing.ukcore.bt.net [109.159.250.147]
9 44 ms 45 ms 44 ms peer2-xe3-2-1.telehouse.ukcore.bt.net [109.159.254.225]
10 44 ms 45 ms 44 ms 195.99.126.71
14 59 ms 45 ms 45 ms 132.185.255.148
15 69 ms 44 ms 45 ms 212.58.244.22
Trace complete.
Deckysw
Message 8 of 37
also did the following packet loss test at 18:45
C:\Users\lipsyboi>ping -n 20 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=230ms TTL=54
Reply from 8.8.8.8: bytes=32 time=47ms TTL=54
Reply from 8.8.8.8: bytes=32 time=192ms TTL=54
Reply from 8.8.8.8: bytes=32 time=174ms TTL=54
Reply from 8.8.8.8: bytes=32 time=46ms TTL=54
Reply from 8.8.8.8: bytes=32 time=48ms TTL=54
Reply from 8.8.8.8: bytes=32 time=45ms TTL=54
Reply from 8.8.8.8: bytes=32 time=51ms TTL=54
Reply from 8.8.8.8: bytes=32 time=1375ms TTL=54
Reply from 8.8.8.8: bytes=32 time=49ms TTL=54
Reply from 8.8.8.8: bytes=32 time=75ms TTL=54
Ping statistics for 8.8.8.8:
Packets: Sent = 20, Received = 20, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 45ms, Maximum = 1375ms, Average = 137ms
C:\Users\lipsyboi>
john46
Message 9 of 37
The results suggest your homeplugs / wireless connection is the possible problem the only suggestion I can make is try an Ethernet connection and see if the problem clears
Deckysw
Message 10 of 37
those tests were all done with the laptop hard wired directly to the router. everything else was disconnected during the test including the homeplugs. at the moment i am usning the comand prompt ping 8.8.8.8 -t to get constant ping results and they do vary a lot
