Rufty
Message 1 of 5
Unwanted switching from BT to FON
My laptop keeps switching from my home BT to BT FON.  I have to then manually switch back to my BT account - but by then I have lost my connection to work when I am mid conversation or livemeeting - and I have to put my pass key in again and log back into work.  Really annoying.
 Espeically as I did NOT opt in to BT FON.
Can I stop it doing this please?
Thanks R
4 REPLIES 4
pottyperson
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: Unwanted switching from BT to FON
If you're using Windows click the wireless icon in the notification area, click BT Fon, uncheck "Connect automatically". Then do the reverse for your BT connection if necessary.
Rufty
Message 3 of 5
Thanks but I already did that - that's why it is so annoying that it keeps switching.  Any other ideas please?
Keith_Beddoe
Message 4 of 5
pottyperson
Distinguished Guru
Distinguished Guru
Message 5 of 5
If you're running Windows 7 the instructions are similar to those for Vista in KB's link.
By the way, if you got BT broadband in the last few years you will be opted in to BT Fon by default. If you want you can opt out here by clicking "Check my status".
