Message 21 of 37
Re: Up to 38MB or 52MB which am I on? Technical insist set to 38MB Sales/Contract 52MB.
Excellent thank you, have done, will wait for outcome.
Moderator
Moderator
Message 22 of 37
Hi @Watkins247,
I picked up your email. I tried calling, sorry I missed you. I've placed and order to try and correct this for you. It'll close tomorrow so can you try checking and let me know if you see any change?
Cheers
David
Message 23 of 37
Will do no problem
Message 24 of 37
FAQ
Hi DavidM here are the latest speedtest results as requested, as you can see IP Profile is still 38.67 and my actual speed is very close to it, the other day my speed came up as just over 39 above the IP profile.
1. Best Effort Test: -provides background information.
Download Speed
38.1 Mbps
0 Mbps 38.67 Mbps
Max Achievable Speed
Download speedachieved during the test was - 38.1 Mbps
For your connection, the acceptable range of speedsis 27.5 Mbps-38.67 Mbps .
Additional Information:
IP Profile for your line is - 38.67 Mbps
2. Upstream Test: -provides background information.
Upload Speed
5.72 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 5.72Mbps
Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Tags (1)
Moderator
Moderator
Message 25 of 37
Thanks for that @Watkins247. Leave it with me and I'll be in touch as soon as I have any updates for you.
Cheers
David
Message 26 of 37
 Download Speed
 38.63 Mbps
0 Mbps38.67 Mbps
 Download speedachieved during the test was - 38.63 Mbps
 Upload Speed
 6.11 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 6.11Mbps
Guessing 38.67 is the max I can get, amazed how close I get to this figure would have thought there would have been a bit of leeway above this and my speed somewhere in the middle of the range.
Still think BT are holding my connection back though.
Thank you everyone for your advice.
Message 27 of 37
Think that all you want. BT don't have the ability to do that. The connection between your modem and the cabinet is wholly controlled by Openreach systems and the sync speed will be the best it can do at the point the connection is made depending on the line conditions at the time.
Message 28 of 37
Not sure I beleive that or may be just a case line is very consistent as the IP profile of 38.67 has never changed since getting Infinity in Oct 2015. Which coincidentally was the speed I was then paying for, was told could get low 40s but deemed the extra cost for a small speed increase wasn,t worthwhile paying for the upto 76Mb.
Took it when BT moved to a up to 52MB service my speed would increase slightly but never did.
Does DLM work all the time, how often does it make adjustments, does it stop working after a stable line for a few weeks?
Does it change the IP Profile for the line, I assumed this was the figure set by BT depending on what package you have.
Message 29 of 37
DLM works continuously to monitor your line. Your IP profile is not set, it is a function of your sync speed. Your sync speed is determined by the length and condition of your line. The only thing that is set is a 80/20 sync speed cap for Infinity2 and a 55/10 sync speed cap for Infinity1
Message 30 of 37
Could my Sync speed still be capped at 38/10 from when I took out infinity? As that's what it looks like to me.
