asdrewq
Message 1 of 10
Upgrade from Infinity1 to 2 - little speed increase
Hi,
I've been happy on unlimited Infinity 1 for a year now, connected at pretty much the max permissible speed (~52mbps down / 9.5mbps up), very stable, low pings, honestly the best internet service I have ever had!
I saw an offer in MyBT to upgrade to infinity 2 so thought why not. I'm on the upper end speed wise on Infinity 1 so thought I'd see a good increase on Infinity2.
The upgrade went through today, & i'm a bit disappointed. Line stats are as follows:
6. Data rate:13196 / 54719
7. Maximum data rate:13203 / 54455
8. Noise margin:5.9 / 6.4
9. Line attenuation:25.5 / 19.2
10. Signal attenuation:25.5 / 19.3
I found the following in the HH5 logs form earlier today from when im guessing I was upgraded, around 3AM:
(634316.430000) PPPoE is up -​ Down Rate=53708000Kbps, Up Rate=13128000Kbps; SNR Margin Down=6.5dB, Up=5.9dB
My question is is there any way I can force some sort of line reset to sync at a better speed? My downstream data rate is pretty much exactly as it was with Infinity1. I know it sounds impatient but my Infinity1 speeds were great from day1 - i'm wondering if upgraded customers are treated differently somehow in the system from new connections.
9 REPLIES 9
Deathtrap3000
Recognised Expert
Message 2 of 10
Re: Upgrade from Infinity1 to 2 - little speed increase
You were at the max your line can support. Upgrading would have no effect on your speed.
pippincp
Sage
Message 3 of 10
All the upgrade has done is raise the software cap from 55Mbps to 80Mbps.
Your line can't support higher than just under 55Mbps the upgrade was a waste of time
stevebrass
Expert
Message 4 of 10
Did you pay more? if so i would complain.
BT's special personal offers are not personal.
asdrewq
Message 5 of 10
I am paying more. Not much, iirc it was £4/month extra but on a longer contract, but if those are the best speeds I'm likely to get I may as well complain & try to go back to Infinity1 😞
stevebrass
Expert
Message 6 of 10
You are payng for a service cannot supply. They need to refund you.
Webby
Message 7 of 10
You've gained an extra 3mpbs on the upload.
Depends on what's important to you.
asdrewq
Message 8 of 10
So 1 week has passed & my connection is now at the following:
6. Data rate: 13042 / 58128
7. Maximum data rate: 13039 / 58022
8. Noise margin: 5.9 / 6.5
9. Line attenuation: 25.5 / 19.2
10. Signal attenuation: 25.4 / 19.2
An increase of 4mbit on the download over what I started at.
Can I expect this to increase further? How do I know when it is actually at the limit my line can support?
Webby
Message 9 of 10
What does http://www.dslchecker.bt.com show for your line?
licquorice
Message 10 of 10
I suspect the extra 4Mbps was due to G.Inp kicking in. You are probably getting as good as you will get.
