Message 1 of 4
Upgrade from Superfast Fibre 1 Unlimited (50 Mb/s) to Superfast Fibre Plus (67 Mb/s)
I have been offered to opportunity to upgrade from Superfast Fibre 1 Unlimited (50 Mb/s) to Superfast Fibre Plus (67 Mb/s). I currently have speed of 30.1 Mb/s (on BT speed test). Is there anything I am missing here or are there any other benefits with this upgrade as it would appear that there might not be any speed benefits attaching? Help appreciated, thank you.
3 REPLIES 3
Message 2 of 4
Re: Upgrade from Superfast Fibre 1 Unlimited (50 Mb/s) to Superfast Fibre Plus (67 Mb/s)
If your current speed on infinity 1 is only 30mb then upgrading to infinity 2 will not give you any speed improvement. The only difference between infinity 1 and2 is the removal of the speed cap   So upgrading is pointless
Message 3 of 4
Many thanks for your help. Kind regards, CWS
Message 4 of 4
You won't benefit from faster speed, but there are other benefits, see http://home.bt.com/tech-gadgets/internet/broadband/why-bt-plus-benefits-fibre-broadband-mobile-11364...
