Hazel_Howorth
Message 11 of 15
Re: Upgrade to ADSL 2+ help
Have done the exchange checker and it doesn't look like there are any errors.
I assume that the current noise margin is the following information:
SNR Margin (dB) up 6.4 / down 3.3
I am not getting any error messages from my router but then again, I don't know where to look 🙂
imjolly
Message 12 of 15
Not sure where your stats are on tplink but this may help. http://www.kitz.co.uk/adsl/frogstats.php
Hazel_Howorth
Message 13 of 15
DSL
Line Status:Connected
DSL Modulation Type:ADSL_2plus
Annex Type:Annex A/L
Current rate (Kbps)  up 1168  down 13776
Max Rate (Kbps) up 1172 down 14092
SNR Margin (dB) up 6.4 down 3.3
Line Attenunation (dB) up 19.8 down 37
Errors (Pkts) 0 / 0
Is that the information you need?
imjolly
Message 14 of 15
i was looking for more the errors not the stats - hec, fec, crc errors and error seconds
Hazel_Howorth
Message 15 of 15
I have looked through every page on my routers information and no where does it have the information you require.  I also did an internet search just in case I was being a bit thick but it does look like that information is not easily available and a script is required.  I don't intend doing that as I fear I will break something.
