Message 1 of 4
Upgrade to fibre 2 same as fibre 1 speed?
Hi everyone!
I am near end of contract and bt show me upgrade options when I log in, but shows the speeds I can get for fibre 2 are the same speeds I get for fibre 1 will my line only go this fast? in which case no point in upgrading,
or can bt fix my line to handle fibre 2 speed? Thanks for any advice 👍
3 REPLIES 3
Message 2 of 4
Re: Upgrade to fibre 2 same as fibre 1 speed?
from what you have posted your connection is as fast as your line can handle  upgrading to fibre 2 does not mean increase in speed unless your line can handle faster - sorry yours can't
enter phone number and post results
Message 3 of 4
Thanks for the reply I had feared that was as fast as I could go! I take it any other company would be the same? Cheers 👍
Message 4 of 4
dslchecker results confirm you cannot get max for fibre 1 never mind fibre 2  any other ISP using openreach network will be the same connection - unless move to virgin
