Mattfox14
Message 1 of 12
Upgraded to 52Mb and now getting slower then previous speed.
I upgraded my BT Infinity 1 to the new 52meg speeds and recontracted as I didn't plan on leaving BT and I was getting around 37Mbps+ I thought its worth it. Since I have been upgraded I am now only getting about 30Mbps, what has gone wrong? I've not moved my HH5 or any of the cables.
Thanks.
11 REPLIES 11
imjolly
Message 2 of 12
Re: Upgraded to 52Mb and now getting slower then previous speed.
Post the stats from troubleshooting then helpdesk
Mattfox14
Message 3 of 12
thank you.
imjolly
Message 4 of 12
Are you using a modem?
can you run btspeedtester and when first test completes then run diagnostic test and post results.
btspeedtester
licquorice
Message 5 of 12
Upgrading will have caused a DLM reset to be applied to your line and may have removed G.Inp. Give it a few days to see if it gets re-applied.
MagnumProject
Message 6 of 12
I have exactly the same issue as you so hoping you find an answer!  Will leave it a few days and check again as suggested in Licquorice's post.
imjolly
Message 7 of 12
@MagnumProject
You would be better tarting your own thread and post your router stats unless you also use a locked modem
Fstbloke72
Message 8 of 12
I'm having exactly the same problem. What a joke,  no wonder they get us to sign a new contract when 'upgrading'. I Should  have stayed with Virgin Media.
Webby
Message 9 of 12
Start your own thread and maybe we can help
Chris-S1S
Message 10 of 12
Same here
