FarleyUK
Message 21 of 35
Re: Upgraded to 80/20, speed is now worse than before!
Well, it's a new day so thought I'd run the speed tests again.....
....and received the exact same speeds. 13Mbps d/l, 15Mbps u/l.
What the hell?
ukdeveloper
Message 22 of 35
same as me..
D/L profile hasnt increased at all. Have been told by BT Customer services it will increase during the 10 days stabilisation processm which is utter nonsence, but try telling that to a script reading asian who has never been to the UK let alone seen or touched the UK BT infrastructure.
UKD.
barkeja
Message 23 of 35
Day 4 after switchover. D/L profile now set to 37Mbps, but D/L speed measured as 31Mbps (via Speedtest.net); same as it always was. BT Speedtester site reports D/L speed of 8Mbps(!) .
barkeja
Message 24 of 35
Day 6 and no change. Have reset modem/router but to no effect. Is it possible we're stuck on some sort of hybrid 40/20 profile? Has anybody seen their IP profile actually move to 80/20 over or after the initial 10 days?
rickydg
Message 25 of 35
Barkeja, it looks as though as you weren't on the maximum profile before 80/20 upgrade that your Iine is already maxed out. I would suggest that your estimate was a bit optimistic. I don't think you'll see faster speeds on the current profile.
jedi118
Message 26 of 35
I'm in the same boat, I had a perfect stable 38 mp dl and since the upgrade it's been as low as 1 and as high as 38. My 10 says have passed and it's settled at 20mps dl eek! At least I know the mods will sort (fingers crossed) please help Patrick !
barkeja
Message 27 of 35
Hi Rickydg. Understand what you're saying but I understood that you don't actually have to be on the maximum D/L profile (within reason) to get some sort of speed uplift from an 80/20 profile. My original estimate from BT when I moved to Infinity (March 2011) was 27/7; the estimate before I switched to 80/20 was 47/10. My issue is not really about what speed my service will move to over time, but that my line is not being allowed to try and train to a speed greater than 37Mb, hence my 40/20 comment. In any event I have now contacted the mods to get their input.
FarleyUK
Message 28 of 35
That's better....!
Just a case of letting the line stabilise 🙂
Aarong
Guru
Message 29 of 35
Nice to see FarleyUK, glad it's starting to stabilise out for ya!
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
barkeja
Message 30 of 35
FarleyUK. Good to hear your speed is going the right direction! Can you tell me when your D/L IP profile was actually changed to 76Mbps? Cheers.
