counttrapula
Message 1 of 19
Upgraded to BT Infinity 76mb, getting 13mb down 1.5 up
Previously had regular BT Broadband, but have as of last Friday upgraded to BT Infinity now that it's available in our area (LEYSDOWN, KENT). From the first speed test results have been 15mb or less down and 1.5 or less up. Been getting lower every day. Was told of this 'settling in' period but I'm not buying it.
Not really accpetable paying for 76mb fibre and getting less than half of the lower package.
Is there anything I should be doing to get closer to this speed? Our exchange is 150 metres down the road.
18 REPLIES 18
john46
Message 2 of 19
Re: Upgraded to BT Infinity 76mb, getting 13mb down 1.5 up
If you use this checker it will tell what cabinet you are on and what services it can receive.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If it does not show a cabinet number it will be because you are on an Exchange Only line which will mean you can not get Infinity because you are not connected to a cabinet, instead you are connected directly to the exchange.
counttrapula
Message 3 of 19
Says everything is available to us.
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)44.533.39.26.5--Available
FTTC Range B (Impacted)37.821.89.25.2--Available
WBC ADSL 2+Up to 7.5--5.5 to 12Available
WBC ADSL 2+ Annex MUp to 7.5Up to 15.5 to 12Available
ADSL MaxUp to 5.5--4 to 8Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
imjolly
Message 4 of 19
with infinity it is the distance to your street cabinet that counts not the distance from the exchange
with that estimate I would have gone for infinity 1 package as estimate is only giving max speed of 44mb just over the infinity 2 max  that assumes you have a good line with no problems
counttrapula
Message 5 of 19
Sorry thats what I meant, it's the cabinet that's about 150 metres down the road.
imjolly
Message 6 of 19
are you sure that is the cabinet you are actually connected to?
was it an openreach engineer or contractor that installed your infinity?
go to hub manager then troubleshooting then helpdesk and post stats 1-12
counttrapula
Message 7 of 19
But we should surely be getting much better speeds based on those predictions?
counttrapula
Message 8 of 19
Was a BT Openreach enginner. He said himself when he got here the cabinet was just down the road by the shop, which is about 150 metres away.
imjolly
Message 9 of 19
run btspeedtester and when first test completes then run diagnostic test and post results
btspeedtester
counttrapula
Message 10 of 19
Heres the 'helpdesk 1-12'
1. Product name:BT Home Hub
2. Serial number:+068343+NQ43014451
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 00:57:16
6. Data rate:1691 / 14092
7. Maximum data rate:1628 / 16116
8. Noise margin:5.4 / 6.0
9. Line attenuation:0.0 / 30.7
10. Signal attenuation:0.0 / 25.8
11. Data sent/received:45.7 MB / 1.4 GB
12. Broadband username:bthomehub@btbroadband.com
