Message 11 of 14
Re: Upgrading a cabinet which prevents all residents from a faster broadband service
Residents who live closer to the exchange than me have all got worse speeds.  So that's not right!
Message 12 of 14
if you are all on adsl2 then it is the distance from the exchange that is the main factor in determining your connection speed  it is distance from the street cabinet when it comes to FTTC connection.
that is right
Message 13 of 14
If you have non fibre broadband , then the service is delivered from the exchange, it’s a rate adaptive system, the longer the line the slower the service, so it follows the closer to the exchange the ‘faster’ the service, that is what the posted graph shows, it plots speed against distance...if someone lives closer to the exchange than you,  but gets slower speed , that needs investigation, bearing in mind it  is the length of the cable from the exchange  , not an ‘as the crow flies’ distance
You haven’t actually posted what speed you should expect and what speed you get, perhaps you could as already stated post your router statistics and the results from a DSL checker like this
https://www.dslchecker.bt.com/
I appreciate that your enquiry is for more than just yourself, but if your details show that your service doesn’t need to be as bad as you state it is, then any fixes could potentially be applied across the board.
Message 14 of 14
@iniltous
The link you have provided has been changed by BT Wholesale it's now:
https://www.broadbandchecker.btwholesale.com
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
