Message 1 of 9
Upgrading from ADSL to Infinity
I recently switched to BT for infinity but on activation day my broadband didn’t work. I spoke with a manager who then found there were no spare ports in the cabinet so my order could not go through. Fibre shows as available on the bt broadband checker and the openreach site. I was left without broadband because of the error. If in the future I try to upgrade to infinity and the same problem occurs will I lose my broadband again or as I’m am staying with BT will they leave my current broadband on. I really want fibre but I don’t want to lose my broadband again. Thanks
8 REPLIES 8
Moderator
Moderator
Message 2 of 9
Re: Upgrading from ADSL to Infinity
Hi @Ejb137 and welcome.
Can you enter your number in the broadband availability checker and post the results, remember to edit your number out before posting.
Cheers
David
Message 3 of 9
Telephone Number on Exchange HARWICH is served by Cabinet 2
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  HighLowHighLow
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
Premise environment
Status
VDSL Range A (Clean)63.346.7181240Available----Yes--
VDSL Range B (Impacted)48.927.415.26.720.7Available----Yes--
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 10--6 to 18Available--------
WBC ADSL 2+ Annex MUp to 10Up to 16 to 18Available--------
ADSL MaxUp to 4--3.5 to 7.5Available--------
WBC Fixed Rate2 ----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
Bridge TapU
VRI--
NTEFaceplate--
Last Test Date18-01-1970
Message 4 of 9
Thank you
Message 5 of 9
Hi @DavidM, I’ve tried to post my results as they showed but I’m not very technical so that was the best I could do. I could message you my details if you need them.
Moderator
Moderator
Message 6 of 9
Thanks for posting the results @Ejb137. I'll need to take a closer look at this so can you please drop me over an email with your details? You'll get the contact the moderators link in my profile.
Cheers
David
Message 7 of 9
I will do that now @DavidM.
Much appreciated
Moderator
Moderator
Message 8 of 9
Hi @Ejb137 Thanks for speaking with me today. This is the link I mentioned where you can upgrade your broadband to BT Infinity.
Message 9 of 9
Thanks very much @NeilO. I really appreciate it.
