Message 1 of 10
Upgrading to Fibre 250 with Halo 1 with complete wifi
Hi, I am upgrading my broadband to Fibre 250 with Halo 1 with complete wifi. It was supposed to go through yesterday but had an email to say it will be done today and my new discs delivered tomorrow. My old plan I was on 160/30 and I used to get approx 140/29 on wired and 120/29 wireless which I was quite happy with. This plan according to my router is :-
Downstream sync speed: 329.103 Mbps
Upstream sync speed: 49.101 Mbps
I done a speedtest earlier on wireless and got 134/47 so I can see the upstream has gone up but the Downstream has only gone up slightly. Just done a test on my wired pc and got 135/48 so really no difference from wireless and less on downstream than I used to get. Will the speed increase happen by itself and maybe take longer into today or will there be something I need to do on my end. Btw the speedtest i used was https://speedtest.btwholesale.com/
Thanks Colin
9 REPLIES 9
Message 2 of 10
Re: Upgrading to Fibre 250 with Halo 1 with complete wifi
what do you get using   https://fast.com/
Message 3 of 10
Just tried and I got 140/43 on my wired connection
Message 4 of 10
Can you post the connection stats from Advanced settings/technical logs/information.
Message 5 of 10
Maximum data rate:77.031 Mbps / 462.569 Mbps
Noise margin:12.4 / 10.9
Line attenuation:0.0 / 25.9
Signal attenuation:0.0 / 25.9
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:3.0 GB Uploaded / 11.8 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-GSAF7T
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-GSAF7T
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:0C:8E:29:31:44:4A
Message 6 of 10
Are you going to post the rest? There's only 2 lines of relevence there.
Message 7 of 10
Apologies for that, I thought I had copied / pasted them all lets try again :-
Product code:Smart Hub 2
Serial number:+091298+1944007243
Firmware version:v0.24.04.11017-BT
Firmware updated:Sat Jan 9 18:06:39 2021
Board version:R01
GUI version:1.71 05_06_2020
DSL uptime:0 days,06 Hours33 Mins52 Secs
Data rate:49.101 Mbps / 329.103 Mbps
Maximum data rate:76.731 Mbps / 466.400 Mbps
Noise margin:12.2 / 10.5
VLAN id:101
Data sent / received:3.5 GB Uploaded / 15.9 GB Downloaded
BT Wi-fi:Activated
Firewall:On
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 8 of 10
You system uptime is only just over 6 hrs, is this due to you resetting the connection? Have you checked for noise on your line 17070 option 2, best with corded phone? You may get a dull background hum with cordless.
Message 9 of 10
17070 is fine no noise at all, we had a 5 minute power cut hence only 6 hours connection.
Message 10 of 10
Ok it looks like the changover may now be complete as its saying in MyBt that my product is Fibre250 with BT Halo1. The issue is my speeds are still all over the place according to 4 speed testing sites (see below). Any ideas how to stabilise my speeds, I have not restarted the router at all as my son is doing online lessons at the moment.  Just to add these tests were all done on my pc in the study which is connected to the router with a wired connection.
Fast.com 160/42
https://speedtest.btwholesale.com/  191/48
https://www.speedtest.net/   158/47
https://checker.ofcom.org.uk/broadband-test  276/47
Speeds on my pc in the hall with a wireless connection .
Fast.com  130/49
https://speedtest.btwholesale.com/  135/47
https://www.speedtest.net/  115/48
https://checker.ofcom.org.uk/broadband-test/127/48
