JPDo
Message 1 of 7
Upgrading to fibre after new connection to ADSL
Hi All,
I recently moved into a new build property and after much difficulty managed to get a BT line installed and connected to ADSL with ok speeds 3 days ago. I know the cabinet I am connected to is FTTC enabled and there is capacity for me to upgrade to BT Infinity. Indeed when I enter my phone number into the Openreach Fibre Availability Checker it tells me that I can order fibre, however the BT Infinity site says no. When I check my phone number on the bt dslchecker it tells me I am connected to cabinet and exchange I thought I was but it lists no services not even ADSL it just says:
Fixed Rate1 ----Available----
ADSL Multicast------Available----
Do I just need to patient and wait for database updates or is this a datbase issue I need to do something about?
James
6 REPLIES 6
pippincp
Message 2 of 7
Re: Upgrading to fibre after new connection to ADSL
I would give it 7 days for the database to be corrected. How do you know there is capacity at the cabinet?
Webby
Message 3 of 7
As above, takes a little while for all of the databases to align.
JPDo
Message 4 of 7
Thank you. The BTOpenreach guy who connected line at the cabinet said there was plenty of space...
JPDo
Message 5 of 7
Thank you - I will let you know how I get on
JPDo
Message 6 of 7
Database updated and order placed today
Thanks again
Webby
Message 7 of 7
Great! Enjoy
