Hi
I have Business Broadband and recently the connection seems to drop out 6-7 times each day. I seem to have no luck with having BT investigate as it seems that as long as the connection comes back after turning the router on and off again (it does), then in BT's eyes you don't have a problem.
I have done my best to find patterns and I have found that it always happens when we are in the middle of a large file upload and then *any* download activity will kill the entire connection. Sometimes it recovers but in most cases I have to reset the router to get the connection back.
I have bt broadband at home and have never experienced anything like this. Its just solid for weeks on end.
Has anyone else experienced a similar problem or would like to offer any clues why its happening? The frustrating BT support staff flow chart of Line Test->Reset Router->"Anything else i can do for you sir?" doesn't seem to cater for my problem hence my posting to this forum.
Thanks in advance for any advice.
Regards
Ian
welcome the forum
however as this is a forum for BT residential customers you really need to post your problem on the business forum http://business.forums.bt.com/ sorry
Apologies..thanks for letting me know...
Ian
