andyjwoodhouse
Message 1 of 3
Upload disconnects
Hi. i have been using a billion router with no issues for the last few years after my hh4 died. recently the wifi started playing up on my billion and i was getting random disconnects. i have purchased a netgear d6400 router about 2 months ago and i am having issues with the connection dropping competely when i try to upload anything. my sons pc was uploading to onedrive and it killed the connection completely on all devices and when i logged into the router the connection had dropped. if i run a speedtest on my mobile phone it also kills the connection when the phone gets to the end of the upload test. is there any settings i need to check on my netgear router or is it some background config changes that are needed that others have been taking about on here. thanks andy
2 REPLIES 2
imjolly
Message 2 of 3
Re: Upload disconnects
can you post stats from your netgear
check for line noise  dial 17070 option 2  should be quiet and best with corded phone
andyjwoodhouse
Message 3 of 3
hi, i am not at my caravan until next weekend so will post the stats then. done the line test at the weekend and it was silent. thanks again, andy
