sc_uk
Message 1 of 9
Upload faster than download
I had Infinity installed today and the engineer told me that he was getting >50Mbps download and 18Mbps upload. When I do a speed test, I get around 15Mbps down, and about 18Mbps up.
I know it's early days and the connection is still probably training, but I am bemused by the fact that the upload speed is higher than the download.
I am connecting via Ethernet.
Any ideas?
8 REPLIES 8
Message 2 of 9
Re: Upload faster than download
could you please run the diagnostic part of the BT speedtest and post its results back here http://speedtest.btwholesale.com/
sc_uk
Message 3 of 9
Here are the results:
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 10.23 Mbps
0 Mbps0 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 10.23 Mbps
 For your connection, the acceptable range of speeds is 12 Mbps-0 Mbps.
 IP Profile for your line is - 52.8 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 10.53 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 10.53Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 20 Mbps
The test result has indicated that you should contact your ISP for further assistance.
MBR123
Expert
Message 4 of 9
your losing signal or speed from somewhere your line is ok its saying 52.8Mbps IP Profile, so somewhere down the line you are losing alot of bandwidth, you sure its ethernet your doing the test with and not wireless?. Track your connections and see. Your Upload is fine it says IP Profile rate is 20Mbps and your getting 10.53Mbps.
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
sc_uk
Message 5 of 9
Yes definitely erhernet. WiFi is off.
Message 6 of 9
please make sure you turn any wireless connection off before checking the speed with an ethernet connection have you got any other devices connected at the time of the test
Deathtrap3000
Recognised Expert
Message 7 of 9
update ethernet drivers,
disable antivirus for the duration of a speedtest
try a different browser
update flash/java
update windows
restart hub (and only hub)
try those
Alan63
Expert
Message 8 of 9
What speed results do you achieve on wireless (n).
would be good to compare and help eliminate the router as a poss source of the prob. If  youget near profile using wireless then you isolated the prob to the cables or dodgy ports.
I seem to rember There  was a problem with some early hubs ports
alan
m1kfb
Newbie
Message 9 of 9
I had this issue as well 8 up and 1down it did make me chuckle I rebooted my HH and when I checked back later all was well.
