Message 1 of 17
Upload speed keeps dropping
Hello,
I've been reading this forum for a few days now trying to find a solution to my problem, but I have not been succesful to date.
My problem is upload speed keeps dropping to as low as 2 Mbs then back to 17 Mbs, it used to be a solid 20 Mbs all the time.
I've contacted the Help Desk, but they were unable to help, and I've reset the Router to factory setting with no change.
This morning the speed were download 75 Mbs, upload 10 Mbs.
I'm using a wired connection and this is a list of my Router Settings:
1.
Product Name:
HomeHub5
2.
Serial number:
+076284+1414006807
3.
Firmware version:
v0.07.03.0814-BT (Type B) Last updated 16/11/2014
4.
Board version:
01
5.
VDSL uptime:
0 days, 13:45:59
6.
Data Rate:
19999 / 79987
7.
Maximum Data Rate:
28999 / 86626
8.
Noise Margin:
15.2 / 7.9
9.
Line Attenuation:
0.0 / 12.4
10.
Signal Attenuation:
0.0 / 0.0
11.
Data sent/received:
315.8 MB / 2.6 GB
12.
Broadband username:
bthomehub@btbroadband.com
13.
BT Wi-fi:
This is my Line Availability:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High
Low
High
Low
FTTC Range A (Clean)
80
66.9
20
20
Available
FTTC Range B (Impacted)
80
56.9
20
12.2
Available
WBC ADSL 2+
Up to 11
9.5 to 13
Available
WBC ADSL 2+ Annex M
Up to 11
Up to 1.5
9.5 to 13
Available
ADSL Max
Up to 7.5
6.5 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Fibre Multicast
Available
Copper Multicast
Available
Any help would be much appriciated.
16 REPLIES 16
Distinguished Guru
Message 2 of 17
Re: Upload speed keeps dropping
According to those stats your upload speed is 20 Mbps
If not, I'll try again 🙂
Message 3 of 17
Can you please run the BT speedtest further diagnostic test this test appears after the first test completes and post back the results
http://speedtest.btwholesale.com/
Message 4 of 17
The results keep changing but this is a sample:
  1. Best Effort Test: -provides background information.
Download Speed
76.08 Mbps
0 Mbps
77.42 Mbps
Max Achievable Speed
Download speedachieved during the test was - 76.08 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-77.42 Mbps .
Additional Information:
IP Profile for your line is - 77.42 Mbps
  1. Upstream Test: -provides background information.
Upload Speed
6.57 Mbps
0 Mbps
20 Mbps
Upload speed achieved during the test was - 6.57Mbps
Upstream Rate IP profile on your line is - 20 Mbps
Message 5 of 17
unfortunately no ISP will act on low upload speeds as they see download as the priority
Message 6 of 17
Thanks for that info, it seems I have been wasting time trying to find a solution but at least I know now!
Distinguished Guru
Message 7 of 17
Please try this speedtest, it may shed some light http://labs.thinkbroadband.com/ispa/
Message 8 of 17
< Speed Test Result
History   Test Again
Download Speed: 73.84 Mbps02550751…
x Down
00
3066.17
56072.34
83666.16
108574.19
133571.12
158672.94
184268.29
210673.59
235572.98
261472.68
286474.28
311574.61
336676.06
361670.97
386973.84
411874.17
436974.41
461971.62
487076.38
512873.87
537176.97
562571.05
587974.19
612473.28
639564.06
663181.01
688272.71
713377.44
738470.68
763575.56
788774.02
813774.98
Upload Speed: 6.98 Mbps0.02.55.07.51…
x Up
00
10
20
30
2815.92
5339.9
7868.23
10367.44
12877.03
15375.17
17887.55
20387.1
22906.85
25406.75
27908.36
30415.83
32947.84
35517.15
38036.87
40525.1
43025.87
45536.25
48036.45
50558.17
53057.41
55557.03
58118.39
60567.59
63107.07
65626.83
68186.66
70684.99
73197.46
75698.72
78217.66
80715.49
Your Latency: 22 ms
This is the only way I seem to be able to post the results, as a table rather then a graph.
Distinguished Guru
Message 9 of 17
No matter, it gives the info.
Have you tried a different PC?
Message 10 of 17
Yes, three differnet PC's
