portal
Message 1 of 17
Upload speed reduced by 50% over last 6 months
Over the last six months, my infinity upstream speed has dropped by 50% to only 4mb/sec. This has taken two massive dives on single days, rather than making a steady decline.
I know this as I have a samknows broadband monitoring unit which uploads my performance and can prepare graphs on the website dashboard.
How can I get BT to review the cabling to my property in the access network? It would seem two distinct events (perhaps provides in my cabinet) have disturbed my line.
16 REPLIES 16
Message 2 of 17
Re: Upload speed reduced by 50% over last 6 months
Hi portal,
If you have a BT Home Hub 5. Please post stats. Go to http://192.168.1.254 > Troubleshooting > Helpdesk.
Please post BT DSL Checker results. Remember to delete out phone number. https://www.dslchecker.bt.com
Please do a BT Speed Test and post results. http://speedtest.btwholesale.com
Is the router connected to the test socket or an SSFP?
Have you completed a quiet line test? If not, dial 17070 and select option 2. The line should be quiet.
portal
Message 3 of 17
Hi, sorry, I don't have a BT HH5 - I run an Asus RT-N66U.  Always have.  That's not changed.  I don't believe it's possible to get line stats from this.
However, here's the other stuff:-
Telephone Number 01473xxxxxx on Exchange KESGRAVE is served by Cabinet 3
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
HighLowHighLow
FTTC Range A (Clean) 32.4 22.4 7 5 -- Available
FTTC Range B (Impacted) 25 12.6 6.3 2.7 -- Available
1. Best Effort Test: -provides background information.
Download Speed
28.2 Mbps
0 Mbps 28.89 Mbps
Max Achievable Speed
Download speed achieved during the test was - 28.2 Mbps
For your connection, the acceptable range of speedsis 20 Mbps-28.89 Mbps .
Additional Information:
IP Profile for your line is - 28.89 Mbps
2. Upstream Test: -provides background information.
Upload Speed
4.05 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 4.05Mbps
Upstream Rate IP profile on your line is - 10 Mbps
This stuff looks fine.  The issue is the 4Mbps upload speed.  This is significantly less than a few months ago.  From the graph below, you'll note 2 or 3 distinct reductions in speed which happen instantly.  This is therefore a change in something, and not a slow degradation.  To my eye, my line has been disturbed in the cabinet, twice.
portal
Message 4 of 17
... and the line is quiet on the test.
The graph above is from my SamKnows dashboard.  I have a monitoring device on my network.
portal
Message 5 of 17
This 2nd graph better shows the upload speed reduction from 6.5Mbps to around 4Mbps.
portal
Message 6 of 17
Anyone able to help?
portal
Message 7 of 17
Anyone?
john46
Message 8 of 17
without any stats it is hard to start helping you
portal
Message 9 of 17
Hi, thanks for the reply.  So is it a case of "No Home Hub 5, no diagnostics?"
Anyway, I've managed to get some line stats off the Openreach modem, which I'll post below.
portal
Message 10 of 17
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 5876 Kbps, Downstream rate = 27948 Kbps
Path:   0, Upstream rate = 4997 Kbps, Downstream rate = 24223 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        6.1             6.1
Attn(dB):        0.0             0.0
Pwr(dBm):        10.4            5.1
                        VDSL2 framing
                        Path 0
B:              43              43
M:              1               1
T:              64              1
R:              10              16
S:              0.0578          0.2743
L:              7477            1779
😧              563             86
I:              54              61
N:              54              61
                        Counters
                        Path 0
OHF:            92665           20143
OHFErr:         0               0
RS:             23721838                739414
RSCorr:         590             31
RSUnCorr:       0               0
                        Path 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    16013787                0
Data Cells:     24545           0
Drop Cells:     0
Bit Errors:     0               0
ES:             0               0
SES:            0               0
UAS:            101             101
AS:             345
                        Path 0
INP:            3.00            3.00
PER:            3.69            17.14
delay:          8.00            6.00
OR:             51.92           233.31
Bitswap:        61              0
Total time = 7 min 28 sec
FEC:            590             31
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            101             101
LOS:            0               0
LOF:            0               0
Latest 15 minutes time = 7 min 28 sec
FEC:            590             31
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            101             101
LOS:            0               0
LOF:            0               0
Previous 15 minutes time = 0 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
Latest 1 day time = 7 min 28 sec
FEC:            590             31
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            101             101
LOS:            0               0
LOF:            0               0
Previous 1 day time = 0 sec
FEC:            0               0
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
Since Link time = 5 min 45 sec
FEC:            590             31
CRC:            0               0
ES:             0               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
