StephenTheCalm
Message 1 of 16
Upload speed still blatantly non existant
having waited 3 days for the line to "settle" my upload speed is still 0.03-0.08Mbps
Just to reiterate the issue,
This is my line stats
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date              High           Low         High          Low
FTTC Range A (Clean)8074.72020--Available
FTTC Range B (Impacted)8066.82017.7--Available
WBC ADSL 2+Up to 14--8 to 18.5Available
WBC ADSL 2+ Annex MUp to 14Up to 18 to 18.5Available
ADSL MaxUp to 8--7 to 8Available
WBC Fixed Rate2 ----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
And this is what i've getting right now...
1. Best Effort Test: -provides background information.
 Download Speed
 73.4 Mbps
0 Mbps77.43 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 73.4 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-77.43 Mbps .
 Additional Information:
 IP Profile for your line is - 77.43 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.01 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 0.01Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Anyone got the foggiest of what on earth is going on here? As it seems to me tech support has no idea.
15 REPLIES 15
john46
Message 2 of 16
Re: Upload speed still blatantly non existant
You need an engineer visit to resolve this
StephenTheCalm
Message 3 of 16
Unfortunately i've already had an engineer visit with no change. The amazing part is that the engineer's job "stops at the wall" so he wouldn't even check the hub! Pretty pathetic service if you ask me.
john46
Message 4 of 16
it is the only way you will get this resolved
StephenTheCalm
Message 5 of 16
Has anyone actually ever seen this happen before and have any experience whatsoever in what might be the cause?
richy17
Message 6 of 16
unlikely if the engineer has already been and refused to check the hub.  Have you got another router or modem you can try?
Have you tried other devices such as a mobile or second PC?  Could it be a firewall blocking connection?  Stabbing in the dark here
john46
Message 7 of 16
not every engineer is like the first one there is a fault which only Openreach can resolve
StephenTheCalm
Message 8 of 16
Cheers Richy  although i've tried everything imaginable, several ethernet cable/ports 3 different computers, disabled the firewall and parental control, I've even moved the wifi channel to the least used frequency.
I do have another modem but i'm not sure about the compatibility to fibre optic? Do you know anything about that side of things?
john46
Message 9 of 16
if you have tried al those things you only have an engineer visit as an option
was it an Openreach engineer that did the install or a contractor
Automan
Message 10 of 16
Is it a Home Hub 5 you have?
Did the engineer install a proper OpenReach master socket with your BT Hub connected to it?
