dpdvx
Message 1 of 8
Usage Monitor
I can not find the Broadband Usage monitor for Infinity. It is NOT shown under 'My services', 'Broadband' on of My BT Is this perhaps because I only moved to Infinity on 13 Feb 2012. Can anybody advise any other way of accessing the usage monitor or is there NO usage monitor for Infinity.
7 REPLIES 7
Aarong
Guru
Message 2 of 8
Re: Usage Monitor
Hi dpdvx and welcome to the forum, try this link https://www.bt.com/appsauth/genericlogin.do?TYPE=33554433&REALMOID=06-014c5771-0026-1001-90c1-83aaa3...
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
dpdvx
Message 3 of 8
Re: Usage Monitor
Thanks for your reply Aarong.
Still NO sign of the usage monitor from your link or from directly signing into My BT.
I can open the My Services, click on the Broadband Icon, but there is no link on the page to a Usage Monitor although from the help file it states that it should be there.
Webby
Message 4 of 8
Re: Usage Monitor
You need to speak to the helpline and find out why.
kitkat388
Message 5 of 8
Re: Usage Monitor
Hi dpdvx.
I got my infinity installed on 20/1/2012 and I got the same problem as you had. I can not find the broadband Usage monitor under My services , Broadband.
Eventually. about 2 weeks ago . When I sign into my Bt. my service . I can see the Broadband Usage monitor there.
So what is my advise is . just wait and be patient. its take them time to set it up.
hope its help .
dpdvx
Message 6 of 8
Re: Usage Monitor
Thanks KitKat,
I wondered whether it was because I had only recently joined Infinity.
I will wait as you suggest.
kentWolf
Message 7 of 8
Re: Usage Monitor
I have had the same problem with the BT site for over a week now, no services shown for infinity or my phone services. Contacted BT yesterday and they say that there is a problem with the website that they are investigating
gspearson
Expert
Message 8 of 8
Re: Usage Monitor
It says today that it is undergoing maintenance - try later - this year?
