stevec59
Message 1 of 9
Usage allowance
I am on the Option 1 package, so 10gb, at christmas I went ove 15.05, so I was chared an extra £10, £5 for the first 5gb, and another £5 fro the 0.05 gb, I thought that was a bit unfair, I do go over most moths, but until by package is up for renewal probably not worth upgrading.
It's a shame that BT don't carge £1 per 1GB over, or if I could have the 9.95gb added to the next month.
We live in hope...
Steve
8 REPLIES 8
Message 2 of 9
Re: Usage allowance
You can upgrade anytime if you wish, there is no penalty, you just start another contract.
See http://bt.custhelp.com/app/answers/detail/a_id/36397/c/346,402,5685
stevec59
Message 3 of 9
Re: Usage allowance
True, but if I wait until the end of my cotract I will get a better deal!
Steve
Distinguished Guru
Distinguished Guru
Message 4 of 9
Re: Usage allowance
They did but changed it a year or two ago. As you've discovered, it's more profitable that way.
chrisii2012
Message 5 of 9
Re: Usage allowance
Its disgusting charging an extra fiver say if you go over only 1GB,should be £1 per GB yyou go over
Message 6 of 9
Re: Usage allowance
It's widely available knowledge. Don't go over, or if you do upgrade, it's simple.
I do feel for the OP though, that is a hell of a lot of money. I don't want to sound awful but you're most likely to get the repsonse of "it's the customers responsbility to check their bill" 😞
stevec59
Message 7 of 9
Re: Usage allowance
Quote
'I do feel for the OP though, that is a hell of a lot of money. I don't want to sound awful but you're most likely to get the repsonse of "it's the customers responsbility to check their bill" :smileysad:'
Agreed, but there again if the usage monitor was real time, that would give me more chance of not going over, but I guess BT want me to go over, easy way to make money.
Bring back price per GB i SaySmiley Frustrated
Message 8 of 9
Re: Usage allowance
You have a real time usage monitor in your home hub providing you don't turn it off or get any disconnections.
Distinguished Guru
Distinguished Guru
Message 9 of 9
Re: Usage allowance
That's true. Some people have reported being unable to access the monitor in MyBT so it might be helpful to show the path (HH2, others may vary):
192.168.1.254 in browser > Settings > Password > Advanced Settings > Broadband > Data Transmitted/Received
You may have to make notes to keep track, but it's better than nothing and right up to date.
