Message 21 of 23
Re: Use ethernet port on wifi discs for broadband
Random but could I use a LAN splitter dongle so can connect Xbox and PS5 to the disc instead of swapping them out everytime.. assuming its not at the same time?
Message 22 of 23
Should be ok if you use a 2/4 port hub or switch.
Message 23 of 23
I use the Ethernet port on the disc to connect a Sonos Play 5 all works ok, also got my sky q mini box and tv connected to another disc using a 4 port switch, all seems to work fine.
