DaveQ
Message 1 of 13
Usenet Throttling
Now that BT have started Usenet throttling, is there any info on whether this is 24 hours a day or are there set tiems?
12 REPLIES 12
Friday
Message 2 of 13
Re: Usenet Throttling
When did they start this?
legitimise_sailing
Distinguished Expert
Message 3 of 13
Do you have any proof that BT have started Usenet throttling?
To say thanks for a helpful answer, please click the white star
DaveQ
Message 4 of 13
Noticed it last weekend so preusme thats when they started.  But as I only use it at weekends might have been earlier.
legitimise_sailing
Message 5 of 13
So lets see the proof then.
legitimise_sailing
Message 6 of 13
Well I just checked here and there's NO throttling on Usenet.
DaveQ
Message 7 of 13
I take it back I must be wrong.  The fact that the newsreader is indicating a download speed of 600K instead of the usual 4M is a figment of my imagination.
legitimise_sailing
Message 8 of 13
It just means you have a problem but it's not BT throttling as I don't have a problem.
Unless you think they're throttling you specifically?
gg30340
Message 9 of 13
toekneem
Distinguished Guru
Message 10 of 13
Did you ever suspect it might be your News ProviderSmiley Wink
toekneem
(EASBF)
