Hi
My BT smart hub been playing up lately. A lot of orange/green light. I'm thinking of replacing the router. I have TP link archer D20 ac750 router but I'm not sure if it is supported. I haven't had much luck trying to set it up. Is TP link D20 supported on infinity?
Solved! Go to Solution.
No. That link describes an ADSL modem. You want one that supports VDSL for using with Infinity.
Have a look at the Archer VR600.
You could have a look at the TP-Link TD-W9970. At same place you saw the first one.
@Unforgiven91 wrote:
What router would you recommend to use in infinity at a budget if no more than £40
There is only one at that price, the 9970 that @Liam_ recommended.
