Message 1 of 2
Using BT Fibre 1 with Draytek 2830n
Hi there,
I have just moved to a rural area and have ordered BT Fibre 1. I am trying to replace my BT Smart Hub 2 with a Draytek Vigor 2830n (for load balancing with a 4G connection). I have simply plugged the broadband cable into the WAN1 socket and with the following settings, but after several hours of searching and fiddling I cannot get the connection to work. Can anyone see what I'm doing wrong?
1 REPLY 1
Message 2 of 2
Re: Using BT Fibre 1 with Draytek 2830n
Is that not just an adsl router and will not work on fibre vdsl
