Message 11 of 17
Re: Using BT Wifi public login is quicker than HomeHub 4 connection at home
the BTWIFI signal from a hub will only be available about 20m from the hub any further and you are very unlikley to connect
as I said you need to keep checking your cabinet to get order in as soon as capacity is increased
Message 12 of 17
Thanks again, and sorry to keep labouring the point, but if none of the houses within 50m are getting fibre how come I can get over 10x the speed when I log onto BT Wifi?
Message 13 of 17
this was a post about BTWIFI speeds last year - it may have changed but I have not seen anything to say it has  https://community.bt.com/t5/Other-Broadband-Discussions/BT-WIFI-with-FON-speed/td-p/1189060
Message 14 of 17
So here are 3 speed tests that I consistently get the same results on.
1. From my BT Homehub 4. Exactly what I expect based on BT Wholesale etc:
Message 15 of 17
then there is this one, when I connnect to BT Wifi with FON.
Always about 10-20% slower than my homehub, which I figure also makes sense because it's prob coming from the neighbour and I'm getting less than them.
Message 16 of 17
and finally this is the BT Wifi connection which is always around the 14-16mb mark, and feels 10x faster than the homehub.
Message 17 of 17
maybe I should just keep quiet and take the better speed regardless where its coming from.. but it's a little frustrating having to log in and some devices obvsiouly can't physically log in to BT Wifi.  It's just a little frustrating that BT aren't able to  connect to the much faster connection which is clearly not very far away 😞
