Message 1 of 3
Using EE Router instead of BT one
Hi all
Possible you can assist me on this.
I was original with EE but in some massive confusion on deals, I'm now been moved over to BT.
I don't have any issues with them.
But I have a EE router with a WiFi disk all set up, so now have to reset all of this to use the BT router I received.
Is there any chance I can still use the EE one and use the BT login?
Or can I use the BT router and connect my EE disk to it?
Many Thanks
Matthew
2 REPLIES 2
Message 2 of 3
Re: Using EE Router instead of BT one
Changing configurations like the connection username may not be possible as it could be locked.
You maybe able to use your EE discs though with the Smart Hub 2
Message 3 of 3
Hello jac
Thank you for the assit.
Sadly this is not the case, i been trying to get this wifi disk set up today with no luck what so ever.
Any ideas on this?
Many Thanks
Matthew
